What controls the Tachometer?
Old Jun 16, 2010 | 01:43 PM
mitfan311's Avatar
mitfan311 is on a distinguished road
Default What controls the Tachometer?
I have a 2001 chevy blazer. 2wd. The tachometer started going crazy. Its being followed by a clear ignition or fuel injection problem. The computer codes show that it is either the Cam sensor or the Crank sensor. I figure that the one that directly controls the Tachometer is the one that needs to be replaced.
Thanks
Old Jun 16, 2010 | 07:59 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Neither has direct control. They send signals to the powertrain control module and that sends a tach signal to an I/C in your dash cluster. It's mainly the crank sensor (I think). BUT if the crank sensor is screwing up you'd also notice your engine running oddly. No crank sensor signal means no fuel delivery. If it's running good but tach is messed up I'd go with a cam sensor first. Running bad like the fuel system is kicking on & off replace the crank sensor.
argon929
May 29, 2010 01:04 PM
stereodesigner
May 28, 2010 03:27 PM
nashs1988
Aug 13, 2009 11:26 PM
Cavalier z24
Mar 5, 2009 03:13 PM
MsRandi
Jul 10, 2006 10:23 AM
