wire location question
Old Aug 10, 2010 | 01:16 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
Default wire location question
I am installing a remote start alarm and after searching this forum and online I have determined what wires go where but i have an issue with one. The install guide says to hook one of the wires to "ignition input of the key cylinder to alarm. Connect to the the ignition wire that provides 12 volts when the ignition is on and while cranking the starter." Is this just the starter wire(the yellow at the ign harness)? My blazer is a 96 ls if you need to know. By the way this wire from the alarm is on the pins that are for safety like the hood pin switch, brake input, it also has the negative door input on it, it is not on the main 5 pin group that consists of the starter output, the accessory,ignition,second ignition, main power input.
Old Aug 10, 2010 | 01:49 PM
whyteb0y's Avatar
whyteb0y is on a distinguished road
http://www.bulldogsecurity.com/bdnew...ngdiagrams.asp
There is a wiring diagram. Hope that helps
Old Aug 10, 2010 | 02:53 PM
dimone545's Avatar
thank you but no that doesnt help. I know where all those wires are I need to now where to put that particular wire that i was tlking about.
Old Aug 10, 2010 | 11:02 PM
The large pink wire in the connector under the steering column is the Ign 1 wire. This wire is hot in RUN & START.
Old Aug 11, 2010 | 05:16 PM
dimone545's Avatar
cool thanks swartlkk
JerryB52
May 16, 2011 11:34 PM
streblo
Apr 2, 2011 03:43 PM
Blaze the S10 4x4 Blazer
Oct 20, 2010 09:50 AM
aspenpup
Aug 4, 2009 01:08 PM
maddog8
Mar 3, 2007 03:23 AM
