ZR2 Lower control Arm question
Old 09-04-2018 | 02:39 PM
Nilism's Avatar
Nilism is on a distinguished road
Well I can definitely confirm that the Part# 45D3317/6 have the WRONG description (they are LS not ZR2) and the RIGHT picture.
I re-ordered the "LS" part with the correct picture, wrong description. Time to wait another few days.
  #22
Old 09-05-2018 | 04:29 PM
man0steel's Avatar
man0steel is on a distinguished road
I have yet to start my front end rebuild and am very anxious to know which part number works on the ZR2. I was going to do as you have done but after two failed attempts to get the right arms I just purchased new joints and bushings. I would rather replace the whole arm than replace the joints and bushings like planned. Please let us know when you get them.
  #23
Old 09-07-2018 | 01:36 AM
Nilism's Avatar
My new arms are supposed to arrive tomorrow. I will update with specific info and links if they do actually show up. Install won't happen for 3 weeks but with a couple of quick measurements I should know right away.
  #24
Old 09-07-2018 | 03:10 PM
Nilism's Avatar
tl;dr:
These are the ZR2 LCAs.
Ok here are the order details:
ULTRA-POWER RK622213 {Click Info Button for Alternate/OEM Part Numbers} (Economy) With Ball Joint Info
Front Left Lower; 4WD; SWAY BAR LINK MOUNTS OUTBOARD OF SHOCK; w/o ZR2 Highrider
ULTRA-POWER RK622212 {Click Info Button for Alternate/OEM Part Numbers} (Economy) With Ball Joint Info
Front Right Lower; 4WD; SWAY BAR LINK MOUNTS OUTBOARD OF SHOCK; w/o ZR2 Highrider
So clearly the description is WRONG, this is a ZR2 LCA and the swaybar link is mounting forward of the shock WRT the vehicle.
I measured everything as best I could and it all works out. I've shown the swaybar link bracket distance from the LCA bushing axis(measure perpendicular from the axis to the mount hold center). I was getting 9.5" +/-. See other photos for sanity.
Attached Thumbnails ZR2 Lower control Arm question-lca-order.png   ZR2 Lower control Arm question-20180907_134250.jpg   ZR2 Lower control Arm question-20180907_134312.jpg   ZR2 Lower control Arm question-20180907_134415.jpg
  #25
Old 09-08-2018 | 08:13 AM
man0steel's Avatar
Yes, those are the correct arms for the ZR2.
  #26
Old 02-03-2022 | 06:41 PM
ACorwin's Avatar
ACorwin is on a distinguished road
Nilism,
Were these the correct LCAs for your ZR2? I have a 1998 ZR2 I am trying to reuild the front end on and cannot for the life of me find the correct LCA's. If these were correct did you install them and have you had any issues. I found factory ones but they will be 650 bucks for the two LCAs and not really wanting to pay that much for two LCAs.
  #27
Old 09-22-2023 | 02:38 PM
CRANNMAN's Avatar
CRANNMAN will become famous soon enough
Default Lower Control Arm P/N Verification
You saved me a lot trouble! I couldn’t understand why the picture of the new part for the location of the sway bar bracket did not match what’s on my 2004 ZR-2. This helped me to order the correct parts. Thank you!
man0steel
03-03-2018 10:39 AM
Blazer_YYC
12-25-2017 10:40 PM
95blazerfrank
08-23-2015 01:49 PM
blitz951
03-25-2013 12:37 AM
Beckyj636
07-13-2010 03:16 PM
Quick Reply: ZR2 Lower control Arm question
