Blazer Light Bar "How to"
Yup, this is still being read by at least one newb. I don't know when I'll get around to putting lights on mine, but this is one of the first threads I subscribed. Looks great, far better than what I managed back in the 80's (last time I installed lights there was a small fire under the dash. Maybe I'll use fuses this time
And to my fellow Americans - Rt hand drive vehicles are fairly easy to get used to. Even shifting with you left hand isn't bad ... No, the controls are easy. Surviving a right turn was the hard part (there were many angry Micks on the streets of Dublin that day!)
Thanks again
)And to my fellow Americans - Rt hand drive vehicles are fairly easy to get used to. Even shifting with you left hand isn't bad ... No, the controls are easy. Surviving a right turn was the hard part (there were many angry Micks on the streets of Dublin that day!)
Thanks again
Im thinking about making a "Cheap light bar how to" just to give people more options as far as the light bar goes. all the light bars that I've found are 50-100$ and with a quick trip to my favorite shopping center (Pick N' Pull) i found just about everything for 10$
Ryan, if you want, I have a spare lightbar (roof rack) & still have the templates for the bracket to fit it to the roof rack. I also still have some of the alu flatbar if you want.
Got too much on at work & at home at the moment. Busy building my decks. This weekend the hot tub needs to go in so I can finish the bottom deck - Then I can finish the fencing at the back. still need to build another two low retaining walls.
texas rebal
Dec 6, 2011 11:01 PM
shibbershabber
Feb 22, 2010 10:07 PM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
