How to: Quad Beam Mod 2nd Gen - DISCUSSION THREAD
Old Mar 5, 2010 | 07:38 PM
svd85's Avatar
svd85 is an unknown quantity at this point
boost3d, I used one relay relay... I don't remember exactly but I did some research and here is what I came up with - the numbers relate to the ones on the relay so the wires should go from that number prong on the relay to the wire specified. Hope it works. when I have time, I will take my headlight assembly apart and take some pics.
30 - Vehicle Ground
85 - High Beam wire - Purple Wire
86 - Low Beam wire - I think its the yellow one
87 - Low Beam Ground wire - I think it is the blue one
Old Mar 6, 2010 | 12:12 AM
boost3d's Avatar
boost3d is on a distinguished road
SVD, Thanks for the advice. Will try it first thing in the morning and see what happens.
Old Mar 8, 2010 | 05:21 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
So grounding out the yellow wire (ON Both Bulbs?) is for the 2000 blazer, the Relay setup is for earlier S10s?
Old Mar 9, 2010 | 01:57 PM
Tony H's Avatar
30 - Vehicle Ground
I'm confused now. The very first post looked like the later S10 just had a grounded wire, Now I see a relay setup and SVD85 has a 2000 S10 in his profile.
I wish I had a wiring diagram for the 2000, I could make sense as to what's going on by jumping Yellow to ground, if all else failed, I'd create my own setup.
Old Mar 9, 2010 | 03:33 PM
Here's the schematic from my thread on the subject:
Old Mar 17, 2010 | 06:36 PM
Tony H's Avatar
Originally Posted by boost3d
SVD what method did you use? Did you just ground out the yellow on the low beam?
Thanks. I have tried multiple ways and it hasnt worked. My friend did it on his 1998 k1500 and is trying to help me but with no luck.
Lots of info here for different years. This link might lead you to page two or three, just go back to page one if it does.
What makes me a bit nervous is that one guy said he burnt a wire on his steering column.
http://www.zr2usa.com/mboard/index.p...pic=6098&st=40
Old Mar 17, 2010 | 10:06 PM
boost3d's Avatar
I got her. Thanks Fellas!
Old May 23, 2010 | 10:31 PM
mykeboy01's Avatar
mykeboy01 is on a distinguished road
I did the first mentioned method (grounding the yellow wire on the low beam) on my 02', and it works AWESOME!!! My only problem, which I noticed today, is that as soon as I shift it into gear, my low beams come on full blast, and I cannot kill them! They are not on while in park. I did do the DRL (bending the fuses) / AHL (relay) disable. Is there something I can do to stop my lights from comming on automatically? And, I did try just grounding the drivers side, and just the passengers side separatly, but to no avail. There must be something...when in gear, they still shut off when I engage the e-brake...I totally give up!
Old Jul 20, 2010 | 01:09 PM
DarkPhantom27's Avatar
DarkPhantom27 is on a distinguished road
My only question is, where did you guys get the relay from, is it new, and if so where do you recommend it be bought at.
Old Jul 20, 2010 | 01:38 PM
svd85's Avatar
you can buy it at any auto place like autozone etc
