Firewall Hole
Old Mar 6, 2010 | 04:14 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
Default Firewall Hole
Hey Guys,
I was given a set of aftermarket fog lights by a friend who didn't want them. I went outside today (first warm day we've had here in WV in a while) to take a quick look. Running the wires will take some time but can be done, but I ran into a small problem. I can't find anywhere to run through the firewall at. I would like to match the switch where the Rear Lift-gate release would be if I had that option. Anyone have suggestions?
Thanks,
Jeff
Old Mar 6, 2010 | 04:17 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
drill a hole and use a rubber gromet.
Old Mar 6, 2010 | 04:26 PM
Blazers.B.Kewl's Avatar
Blazers.B.Kewl is an unknown quantity at this point
Figure out where all the other wires go through the firewall at. When I ran my wires, I found where a loom went through the firewall on the passenger's side down at the bottom. I stuffed a flat head through the opening from the inside and then poked my wires through and took out the flat head (the flat head was only used to keep the hole open and large enough to poke wires through). But that's on a '92. It may be different for yours. But you should still be able to use existing grommets if you don't want to drill your own.
BRoss99
Oct 27, 2014 01:50 PM
kennybopaloo
May 16, 2010 06:48 PM
carterx
Nov 30, 2009 01:39 AM
EuroGoldLS
Jun 15, 2007 04:11 AM
Kaffeene
Apr 25, 2007 10:03 PM
