How do you run your wires?
Old Mar 13, 2008 | 01:37 AM
TripleBlackBlazer's Avatar
Default RE: How do you run your wires?
Grommet location, check it out.
Old Mar 13, 2008 | 02:10 AM
mdehoogh's Avatar
ORIGINAL: ltown21
well it helps a ton to move your seat forward as far as it will go then slowly pull the plastic away.
itswill be eveneasier if you just pull the passenger seat. 4 bolts and about 10-15 minutes extra time will give you a lot more room to work around in there and give you easier access to the b pillar.
plus, you have a chance to find all the money that has fallen out of your passengers pockets and it makes a good oppurtunity to vaccuum under the seat.
Old Mar 14, 2008 | 12:27 AM
NoPh33rRaCiNg's Avatar
NoPh33rRaCiNg is an unknown quantity at this point
ORIGINAL: blazinloud
Well they say to run power and rca's down opposite sides.....mine are on the same side with no problems...cant promise that for you however....
depends on how shielded your RCA's are too, how much noise is able to get in from outside sources so its best to run power on opposite side as rca's
Old Mar 15, 2008 | 04:40 PM
theonetrueapex's Avatar
theonetrueapex is an unknown quantity at this point
Just to be on the safe side, I ran my rca's down the passenger side and the power cables down the drivers. All of which was under the trim.
Old Mar 15, 2008 | 06:12 PM
blazinloud's Avatar
hmm, I got the cheapest rca's I could find.....stingers....
Old Mar 15, 2008 | 11:53 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
i ran my RCA's down the driver side, and power down the passenger side.
Old Mar 16, 2008 | 12:06 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
ORIGINAL: Jharper
X2... seemed like a good idea when I did mine, because the hole where your antenna cable runs through is in the passenger floorboard...
Old Mar 16, 2008 | 01:23 AM
thegr81's Avatar
I tear out my interior when I do a system install, with doing that I run the wires down the center of the vehicle putting rca's on one side and power on the other side of the transmission hump then into the back. After I run all my wires and do a test hookup before putting the interior back in I get out the dynamat and dynamat the floor and whole cab including roof!! This is just how I do my installs on my own rides!!
bigdaddykane93
38
Feb 10, 2018 10:37 AM
BlazinClinton
Mar 1, 2011 08:14 PM
bigdaddykane93
Sep 22, 2009 08:42 AM
Argo123
Oct 18, 2008 12:31 PM
rogggg1020
Sep 24, 2008 06:53 AM
