How-to install hidden switches
Old Jul 30, 2009 | 02:23 PM
turtlehumper2000's Avatar
turtlehumper2000 is on a distinguished road
Default How-to install hidden switches
Ok so i was looking for a place to mount the switches for the auto bottle opener and a purge. I wanted a place where they wouldnt be in plain sight. So i had the idea to build a mount inside my ash tray since i dont smoke and if you smoke in my truck i keel you. You can do this with any switches you want i just used these because they were best for what i was doing.
What you need:
A peice of plexi-glass
the switches you want to install
some sort of silicone
First you measure you ash tray and make a pattern on your plexi glass
Then you cut out the pattern. I used a Circular saw with a plywood blade on it.
Then i use a dremel to cut down the peice in the middle of the ash try to make room for the plexiglass:
and i drilled a hole in the back for wires:
Then i used a sanding disc on an angle grinder to shave off what i needed to to make it fit perfect.
I then drilled the holes for the switches. Once again i used a dremel for the longer switch. Then i sanded it real quick so i could paint it:
then i painted it and installed the switches:
then i hooked the wires up and installed the plate into the ash tray and used the silcone to seal it (which looks like crap on mine because i dont have a caulking gun im gonna scrap it off and redo it later)
and back into the car it goes
was thinking about buying an ledstrip from advance to put above it so i can see it at night.
Sisk
16
Dec 13, 2009 08:39 AM
DJ 4x4
Mar 5, 2009 07:10 AM
Argo123
Sep 19, 2008 10:44 AM
m00nwater
Sep 6, 2007 07:36 AM
02 Vortech
Apr 1, 2005 01:36 AM
