JVC/Arc Audio build
Old Nov 21, 2009 | 01:08 AM
loomdog32's Avatar
loomdog32 is on a distinguished road
Default JVC/Arc Audio build
I finally got my HU back from JVC... Now to start looking at getting the equipment installed (which will start when I have door locks that lock)........
EQUIPMENT LIST
JVC KW-NX7000 w HD, BT, Sirius
***I have no idea how Im gonna get all that installed... Been kicking around a couple ideas...***
Arc 6000 - 6.5 Component in front (probably mount in kicks)
Arc KS600.6 - 6.5 Component in rear (looking at stock location - I have a trick up my sleeve for that)
2x Arc 12 in Ported Box (**these might get swapped for a single Arc Flatline 12 or ID MAX 10 in a sealed box**)
AudioControl 6XS (thinking of getting Epicenter)
Arc KS300.4 - 4 x 90watts @ 4ohm (**this might get swapped for Arc KS900.6 - 4 x 100watts + 2 x 155watts @ 4ohm - bi-amp front components**)
Arc KS300.2 - 1 x 700watts @ 4 ohm (**if subs change this will get swapped for Arc KS1000.1 - 1000watts @ 2ohm**)
DC-AC inverter with gameplate.. I had a Wii and PS2 in the previous vehicle, looking to find a NES-on-a-chip/plug-play system as the older games are actually playable on 7" screen
Im gonna start by laying sound deadening material the entire car.. debating if Im gonna do the roof.. Ive done a ton of research on that subject (Im tring to stay out of a debate on this, but if someone wants to start one, Ill gladly give my 2 cents in a different thread).. Im going to use Peel & Seal (yes I know its asphault based. I know it WILL fail in 3-5 years, maybe sooner, considering 100 summers. I know it MIGHT stink..).. My local Lowes carries it for $13.59 out the door.. Figues to start with 5 rolls and see how much I get done.. If I need more, Ill get more at that time....
I have concerns with having this much equipment in a vehicle that is easly broken into.. I would like to have as much of the system hidden as possible... Any ideas??? I am gonna wire most everything up when I do the deadening...
95_Blazer
Dec 26, 2007 08:12 PM
nofear17bmx
Aug 3, 2007 11:24 PM
drefda
Feb 23, 2007 10:44 AM
Aquahallic
Sep 6, 2006 02:06 AM
