Multi Channel Amp
Ok so I have never ran a multi channel amp, only mono amps to my subs. And a bit curious about them, what the advantage would be.
In my blazer I run an alpine deck (think its a 50w x 4) with sony xplod speakers (and forget which ones i put in the dash ) and an alpine mono amp and alpine 10" sub.
In my vibe i run a kenwood ddx-418 (22w x4) with JBL Gto speakers, I wired out the factory amp, running an alpine mono amp with the same alpine sub from my blazer ( Vibe = summer car, blazer = winter car) so i switch the sub back and forth between the two cars.
In the blazer the mid ranges all sound perfectly fine and I can turn it up as loud as I want. In the vibe 95% of the time its fine and as loud as I want but I have found the max on it where the speaekers start to crack and get distorted, now is this a limitation of the speakers or limitation of the power supplied to them.
What is the advantage of running a multi channel amp for the speakers, and what would you run and how would you hook it up if you continued to run the mono amp just for the sub?
