Multi Channel Amp
Old Dec 25, 2012 | 01:35 PM
streblo's Avatar
Default Multi Channel Amp
Ok so I have never ran a multi channel amp, only mono amps to my subs. And a bit curious about them, what the advantage would be.
In my blazer I run an alpine deck (think its a 50w x 4) with sony xplod speakers (and forget which ones i put in the dash ) and an alpine mono amp and alpine 10" sub.
In my vibe i run a kenwood ddx-418 (22w x4) with JBL Gto speakers, I wired out the factory amp, running an alpine mono amp with the same alpine sub from my blazer ( Vibe = summer car, blazer = winter car) so i switch the sub back and forth between the two cars.
In the blazer the mid ranges all sound perfectly fine and I can turn it up as loud as I want. In the vibe 95% of the time its fine and as loud as I want but I have found the max on it where the speaekers start to crack and get distorted, now is this a limitation of the speakers or limitation of the power supplied to them.
What is the advantage of running a multi channel amp for the speakers, and what would you run and how would you hook it up if you continued to run the mono amp just for the sub?
Old Dec 25, 2012 | 02:15 PM
Irocz327's Avatar
Irocz327 will become famous soon enough
In my truck I run a jl audio 300/4 that runs my door speakers (infinity referance) & a 1100 alpinealpine mono amp powering a alpine type r 12 & love it. So that's how I did mine. I hope that helps some.
Old Dec 25, 2012 | 03:15 PM
99bblazer99's Avatar
99bblazer99 is on a distinguished road
using a multi channel help gives you better crossover points for your speakers. louder and more clear if you know what your doing.
Red 96'
Nov 11, 2011 11:00 AM
mdehoogh
Jan 16, 2008 11:28 PM
nofear17bmx
Nov 30, 2007 09:46 PM
drperry
Jul 13, 2007 03:12 PM
RCarp48
Apr 2, 2007 07:19 PM
