Stereo and speakers
Old Mar 17, 2008 | 07:20 PM
Tymaraux's Avatar
Tymaraux is an unknown quantity at this point
Default Stereo and speakers
Got a couple of questions i could use help with.
First, i am having problems with my speakers. Only some of them seem to work the majority of the time, while others might turn on after i've been driving for a while... Any ideas about what is going on?
Secondly, I bought a new stereo to replace the factory stereo, and i have no idea whether the factory model is DIN or not... i was about to remove the dash coverings, and thought i should get this figured out first. Suggestions?
Thanks in advance.
Old Mar 17, 2008 | 07:47 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: Stereo and speakers
loose wiring. what year blazer do you have?
Old Mar 17, 2008 | 08:32 PM
Tymaraux's Avatar
I have a 95. Is there an easy way to check where the wires might be loose?
Old Mar 17, 2008 | 08:40 PM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
At the speaker and behind the head unit
Old Mar 17, 2008 | 08:42 PM
mdehoogh's Avatar
The place I would start would be the radio, check and make sure the wires are connected properly. If they are all okay, then I would check the speakers and make sure everything checks out...
If you can't fix it by ensuring good connections at the radio/speakers, theres a chance that there could bea short in the wiring somewhere in between. No simple way to check for a short besides inspecting the entire length of the wire.
Old Mar 20, 2008 | 06:19 AM
hillbillyinOhio's Avatar
factory radio is a din and half, will look nice with the proper dash kit. check out my sticky on top of the av page, Install parts. If you are at all handy, run new wires, fairly easy in our trucks. only pain is the door jamb boot. but a hanger will solve that pretty easy
Old Mar 25, 2008 | 04:49 PM
Tymaraux's Avatar
What is the easiest way to get to the speakers in the doors? And how likely is it that they will have to be replaced?
Old Mar 25, 2008 | 09:41 PM
two 7mm bolts under cover in door pull. one plastic screw by lock mechanism. clips the rest of the way.
Enraged_Bacon
Aug 24, 2012 07:00 PM
98Ltblazer
Oct 15, 2010 08:22 PM
degaine_designs
Aug 7, 2009 11:05 AM
Red Tomato
May 21, 2009 01:18 PM
lennyblazer
Sep 25, 2007 05:31 PM
