Stereo Wiring and Install Parts
*** EDIT ***
I found at least part of the answer today. I've been slowly working on putting a new Alpine headunit in and I bought a module to retain my steering wheel controls. Well, I had to hookup that module to one of those wires tonight, so I'm assuming both are associated with steering controls somehow.
I have a 2004 Blazer Extreme. I have installed a aftermarket radio in it before and had to buy the door ding...the part for that extra wire and chime cost me a 100 bucks...I have read that you can piggy back the the power wire from the fuse box or maybe the ignition hot wire. I have lost the part I purchased and there's gotta be a better way then spending a 100 bucks again...You seem to know your stuff can you help me out? Is the wiring harness I need 70-2003 (M)? Thank you
I Sorry if this has already been answered i have a 2003 blazer stock rds with a aftermarket HU.It has component speakers tweeters in the dash trying to find were the front door speakers meet the tweeters to tie them into a crossover and put aftermarket speakers in (want to use the wire that's already there)does anyone know were i can find this splicing location?
Hi all, I'm getting ready to install a stereo into a 2004 S10. I've heard that there is a module that I'm going to need for the truck to still work after I take out the factory head unit. I could see that if the truck had OnStar and the other normal useless crap, but this truck has freaking manual windows. Am I going to HAVE to have that stupid thing, or am I going to be ok if I just hard wire everything instead of using the wiring harness kit (which I've done numerous times).
Also check on the radio, if it says RDS on it, chances are you will need the harness. But if your truck is the base model chances are you aren't going to have it because I believe the RDS radio was optional and not standard equipment.
Originally Posted by hillbillyinOhio
For 2002 up blazers the wiring is as follows:
Radio 12v orange+radio harness
Radio Ground black-radio harness
Radio Ignition dk. green+radio harness
Radio Illumination gray (dimmer)+radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- tan - gray+,- radio harness
RF Speaker +/- lt. green - dk. green+,- radio harness
LR Speaker +/- brown - yellow+,- radio harness
RR Speaker +/- dk. blue - lt. blue+,- radio harness
I have 03 Blazer
Im a little confused on 2 wires. Red and Yellow on the new stereo harness Red = Accessory , Connect to Ignition circuit or switched 12 volt source... Yellow = Memory, Connect to battery circuit or constant 12 volt source. I only see " Radio 12v orange+radio harness" In this post so Im wondering where the Memory wire hooks up. I believe in my old car I wired yellow and red together but the radio didn't shut off with the ignition and I dont really wanna do that.
Power Antenna N/A
I have 03 Blazer
had everything done in no time.
