sub question
i have a 2000 Jimmy 2Dr with 1 JL 13.5in sub in the back that sounds great. but the only thing that aggrivates me a little is whenever the sub is on kinda loud the back door handle rattles like crazy. my handle is inside my truck not on the outside. is there any way to stop this??
thanks
thanks
i will let you know as soon as i get my truck back. im pretty sure its the internal working though. i should have it back tonight and an exact answer for you tomorow. but is there anyway to stop the internal workings?
basically what your going to have to do is take that panel off and pinpoint the rattle. theres always a way to fix a rattle, but you first have to know the direct source.
First remove the3 screws on butt of the panel closest to the car, and the one on each side of it as well. Then remove the two screws under the handle and remove the handle. Now with a litlle tug the panel should lift up, it is held on with a couple snaps so it might be snug. After that you should be able to see whats rattling and take care of it. If you know what it is but dont know how to fix it just let me what it is and i can suggest a solution...
Putting Sound deading under that panel would probably be a big help in this situation...
alright man thanks for the help. i should get to this at least by the weekend deoending on what time i get off work the rest of the week. if i get it apart and cant fix it il send you a pm.
thanks
thanks
vagnozzi
14
Apr 27, 2007 12:33 PM
