Tech Guru's
try this and let me know what happens to the LED
Press and hold in the programming button you found. Turn ignition on and back off (while holding button in) Release the button and press and release it once more. then peep your led. what is it doing???
Hillbilly, When I did that the led flashed 6 times and kept repeating that until I started the truck when I shutthe truck off and armed the system it was still flashing 4 times.
DrPerry, I don't have a white remote I have the blue one with display and four buttons.
I believe my shock sensor isn't working( hasn't for a while now) Just never flashed any more than normal. As for the 6 flashes being a loose wire, Why would it come up now. I tried the hood pin and it works just fine.
I had the hood open and I held down the hoodpin then remote started the truck and let go of the pin and it shut off. Same to check the alarm let go of the pin and the alarm went off. What unit would you be speaking of?? I can't understand why they would pop up noew either since I had no problems till I did this. But man Does it ever feel good to not be locked in my truck anymore!!!!!
mrshaneb
31
Jul 3, 2010 01:16 PM
