Will 5.25 2 way Speakers Fit In both front and rear doors of my 1997 Chevy Blazer LT?
Old Dec 31, 2017 | 08:16 PM
Jacob Dudley's Avatar
Jacob Dudley is on a distinguished road
Default Will 5.25 2 way Speakers Fit In both front and rear doors of my 1997 Chevy Blazer LT?
Hey I was just wondering if I had the right speakers for my 97 Blazer, they’re 200W BOSS Speakers that are 5.25 inch and was wondering if 200W Will give me a decent amount of bass.
Old Jan 2, 2018 | 08:26 AM
El_Beautor's Avatar
The factory door speakers are 6.5". You can use a 5.25" speaker, but you'll need to make an adapter plate. Pretty simple to do.
Old Jan 6, 2018 | 12:02 PM
Default How would I make a adapter plate?
How would I make a adapter plate? For my speakers?
Old Jan 8, 2018 | 10:10 AM
Snap-Off's Avatar
Snap-Off is on a distinguished road
Crutchfield has the adaptor plates if you'd rather get them pre-made. Just select the year and your blazer , 2-door or 4-door etc..
You'll find the plates.
El-Beautor is just trying to help you save some change because they are around $20 a set..
Old Jan 8, 2018 | 10:14 AM
Snap-Off's Avatar
These are for a 97 4-Door Blazer:
https://www.crutchfield.com/g_103200...s.html?tp=2824
If your configuration is different , then just make the required changes on that site..
Old Jan 10, 2018 | 09:56 AM
El_Beautor's Avatar
If you want to make your own you can do it from ABS plastic, or MDF board. If you use MDF or any other wood product you should also coat it with something to water-proof it as it will be exposed to at least a little humidity/moisture in the door. Just use the factory speaker as a template to cut the outside ring, then use the template with your aftermarket speaker to make the inside hole in your adapter ring.
teamrojas
Jan 5, 2013 01:58 AM
ComputerNerdBD
Mar 8, 2012 07:41 PM
s14sh3r
Feb 13, 2011 05:48 PM
kickme005
Aug 24, 2010 12:38 PM
celchlepp
Feb 17, 2008 03:56 PM
