Wiring Power inverter to ignition source
Old Sep 21, 2012 | 12:52 PM
Unlimitedsp's Avatar
Default Wiring Power inverter to ignition source
So Im installing a power inverter in the rear and want it to be wired to an ignition source in order to avoid manually flipping it on and off. This is what im running.
Amazon.com: Cobra CPI 480 400-Watt 12-Volt DC to 120-Volt AC Power Inverter with 5-Volt USB Output: Car Electronics Amazon.com: Cobra CPI 480 400-Watt 12-Volt DC to 120-Volt AC Power Inverter with 5-Volt USB Output: Car Electronics
After some thought this is what I have come up with.
I plan on tapping into the switch contacts on the inverter and run a relay to it from an 12V switched ignition source. That way the inverter is flicked on and off with the ignition. I just want some input to make sure I am correct on my wiring and relay setup.
jaybird33081
Apr 22, 2010 01:07 AM
NVANZEE
Feb 1, 2009 05:46 PM
EuroGoldLS
26
Jan 29, 2009 09:32 PM
ryacu
May 3, 2006 11:28 AM
