2000 Blazer
Old Aug 28, 2022 | 08:47 AM
DDietrich's Avatar
DDietrich is on a distinguished road
Default 2000 Blazer
I installed a Rough Country 2.5in lift on my 2000 chevy Blazer. Now I keep blowing cv axles. Should I install the cv axles used in the SR2 modal?
Any help here would be very appreciated
Dean
Old Aug 28, 2022 | 11:31 AM
AJBert's Avatar
Did you drop the front diff? Is so, are the torsion bars cranked up?
Old Aug 28, 2022 | 12:21 PM
Torsion keys are a must to have the front end sitting proper with the lift, also thw drop bracket for the diff and wedge for the passenger side.
the real issue is the cheap rubber they are using with the cv axles now a days...
The zr2 cv axles will not fit, even with the lift.
Old Aug 28, 2022 | 12:38 PM
DDietrich's Avatar
Yes we dropped the dif and the torsion bars are cranked up
Dean
Old Aug 28, 2022 | 12:39 PM
DDietrich's Avatar
Thank you for the input
Dean
Old Aug 28, 2022 | 12:46 PM
Are the cv joints breaking/wearing out or are the cv-joint covers coming off?
I found when I did my lift that the inner joint covers detatched from the larger flange.
I was able to fix one with a large hose clamp and had to replace the other.
The original joint covers are pretty stiff compared to the neoprene ones you can get now.
Johnny mcc
Apr 27, 2022 12:04 PM
BritishColumbiafishing
Feb 15, 2019 06:08 PM
blazer37
May 4, 2011 03:59 AM
nonstop
22
Jun 7, 2009 07:16 PM
jaredi1989
May 31, 2008 08:08 PM
