2000 Boring Blazer Build
Old Dec 6, 2013 | 07:00 PM
  #91
newguy's Avatar
the video says private, cant see it
Old Dec 6, 2013 | 08:23 PM
  #92
Tajohns34's Avatar
It is now public. I'm not sure how it got marked private.
Old Dec 6, 2013 | 11:08 PM
  #93
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
So have a new development. I have a horrendus engine knock that just started. It sounds like it is coming from the driver's side of the engine. Also it goes away when it warms up. Time for a V8 swap?
YouTube
That doesn't sound good at all!!!!:sounds to me that there are 2different noises u are hearing here......obvious lifter noise, & sounds like there is also lower end noise! my guess is a v8 swap may be in your near future!!!!
Old Dec 7, 2013 | 06:42 AM
  #94
Tajohns34's Avatar
If a V8 was a direct bolt in I would seriously consider it, but financialy, there is no way. What I do find odd is that the noise goea away after about 5 - 10 minutes of driving it.
Old Dec 8, 2013 | 11:02 PM
  #95
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
It's is a direct bolt in you run two more injection wires or have the old harness then endings mounts and headers and prob a e fan
Old Dec 9, 2013 | 07:13 AM
  #96
Tajohns34's Avatar
I already have an e-fan. However I drove about 100 miles this weekend and it only made the noise twice. It did it for about 5 seconds when I first started it before I wen to the store on Saturday, and for about 1/2 a second yesterday when I was leaving my parents' house. It hasn't done it at all today.
Old Dec 9, 2013 | 09:45 AM
  #97
Tajohns34's Avatar
Here is what I was working on when the engine noise started, totally unrelated. I had a coolant leak, and I replaced the upper radiator hose, because that is what i thought was leaking. It wasn't the cause of the leak, but it needed replacing anyway. my water neck (above the radiator) was shot.
rust bubbles, no good
old & new.
Attached Thumbnails 2000 Boring Blazer Build-20131206_172530_zpscc31d26b.jpg   2000 Boring Blazer Build-20131206_172526_zpscf234ce0.jpg   2000 Boring Blazer Build-20131206_172521_zps646aad3b.jpg
Old Dec 9, 2013 | 11:39 AM
  #98
Tajohns34's Avatar
I finished installing the cover for my amps. I used 2 80mm PC fans, since they run on 12v. I used a 3 inch hole saw. the one that is mounted lower is the intake fan and the upper is the exhaust. I am running them off the remote turn on for the amp. I may wind up getting a 5 - 9 volt voltage regulator to slow them down since they are kind of loud. But for now, here are some pics.
Attached Thumbnails 2000 Boring Blazer Build-20131204_171908_zps6f4de1d4.jpg   2000 Boring Blazer Build-20131207_124425_zps65aa4ed3.jpg   2000 Boring Blazer Build-20131207_144438_zps83ec8911.jpg   2000 Boring Blazer Build-20131207_144700_zps1be8f498.jpg
Old Dec 9, 2013 | 02:48 PM
  #99
BigBlackBlazer's Avatar
BigBlackBlazer is on a distinguished road
what is that on-star cover? I'm guessing it is only for blazers with on-star, but where does it usually go?
Old Dec 10, 2013 | 06:43 AM
  #100
Tajohns34's Avatar
It is the on-star cover. Since I pulled out the on=star I just mounted the amp where it used to be. Then I figured I might as well throw the cover back on.
