2001 LS off road build
Here is the bracket you need to install so those parts will work.
https://www.outfitterdesign.com/1-to...m-bracket.html
Quilt over?? Coil over, not sure if it can he done, anyway I have a 4 door ls, not the best for off roading unless you change a few things, i needed to get a custome front shaft as the zr2 blazers have a longer one, the rough country shocks are garbage ×10, I have gone through 4 pairs in 3 years. As i am now changing to bilstine 1500 if i can find some that fit!, the steering box is (sloppy) i added a rough country steering stabilizer, the leaf springs are very long and can be worn down very easily if you load up. I'd recommend adding 2 more stacks. Also fitting 32inch tire you will definitely need ofset rims and to cut a bit of rear bumper.. do your fuel pump befor any of this stuff.
The truck is very capable off road if you know what to do
![](https://cimg3.ibsrv.net/gimg/blazerforum.com-vbulletin/640x480/11302012209_392384738602b3be6681f806f7b02e9c63ad866d.jpg)
![](https://cimg5.ibsrv.net/gimg/blazerforum.com-vbulletin/640x480/11302012212_38fe466de0be3185576e3f52eaf71510ab873eff.jpg)
empi 00-9570-8 is the part number and yea for a older VW
ok thanks I'll check in to that, Yea I don't cut it any slack lol. Do you have any recommendations for the best spider for this type of use, mine is starting to leak and needs replaced.
I went to a driveline shop and got a front prop shaft done they did all the work for me as it was a custome shaft. I did some damage with the stock 1 with only a 3 inch lift
