2004 blazer
Old Nov 27, 2015 | 02:36 PM
cwbrown13's Avatar
cwbrown13 is on a distinguished road
Default 2004 blazer
hi i have a 2004 blazer. so far i have magnaflow y pipe and cats magnaflow muffler air intake and hptuned. was looking for some more ideas on what i can do for power with out ripping the engine apart or a super or turbo charger
Old Dec 4, 2015 | 10:36 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
For beginners,when was the last time you`ve changed out the spark plugs,spark plug wires?Or even a new coil?These 3 things along, makes a world of a difference.Another idea (which is costly) to have a true set of dual exhaust installed.Thats when you have a 2 1/4 pipe running from the driver side manifiold through the cat, through the muffler into the tail pipe.Repeat the same task on to the passenger side.You would have an exhaust pipe for each side of the motor.That`s what you call "A true dual exhaust" But Ive never seen true dual exhaust on any blazer before.I`ve seen guys who did the same thing you`ve done on You tube, but not true dual exhaust.
Old Dec 4, 2015 | 12:39 PM
Going to true dual exhaust isn't going to gain you much over what you have already done and many people do not like the sound if they do go that route. True duals are also quite difficult to package in under these trucks as space is quite limited. Dual 2.25" pipes would be overkill on these engines as well.
As far as power mods, I believe there are a few cam grinds available that would help matters, but it won't be a gain anywhere near a turbo or belt driven lung.
Most people that want HP either turbo or V8 swap and neither are cheap.
The fuel system on these trucks is a major restriction when it comes to performance modifications. The fuel injectors that came stock in your truck are rated at 23.1lb/hr at 63psi which I have heard limits power output to somewhere around 300hp. Many that go to forced induction swap over to the marine 4.3L intake (more info on the swap HERE) that is all aluminum and has external, standard design fuel injectors.
MTopper
Jul 12, 2011 12:19 AM
lionel2
Apr 16, 2008 04:45 PM
Chev it or leave it
Nov 22, 2006 10:08 AM
vol
Oct 30, 2006 12:10 AM
white04blazr
Suspension Tech
Oct 5, 2005 11:06 PM
