99 4 door blazer
Old Feb 2, 2017 | 01:01 PM
Question
I've been slowly picking parts here and there to get my blazer to where I want it to be. Lucky for me, Kijiji has been on my side. Picked up my brush guard and tail light covers for 100$, my s10 offset rims for 40$, and tomorrow I'm picking up my nerf side steps for 200$. After all this I got my 2" body lift I want to put on in the summer and looking for a zr2 tire carrier.
To all the 4 door who already installed a carrier, I've checked the walk throughs on here and I'm still a little unclear on the reinforcement for the side panel. I'm thinking just a few layers of steel shims? Any ideas/referrals? And out if a long shot, any one looking to make a few bucks by getting rid of theirs if not wanted/ needed?
One last thing. For the last few months I've been having a hard knocking while turning corners and parking. I've taken it in and looked myself, shop says the front end is good, I went under and found my torsion bars looser then a hooker on special.... Pardon my french.... So I tighten them up and got rid of the tire rub I had but the clunks are still there... Any ideas?
Oh, and can't forget the fender flares!!
Old Feb 2, 2017 | 02:17 PM
rexmburns's Avatar
Super Moderator
I think my tire carrier install starts somewhere around page 50 in my build thread. I can hang on mine (I'm 230lbs) and swing along with a 40" tire mounted on it and I don't have any issues with the way I did mine.
Old Mar 11, 2018 | 07:40 PM
so instead of starting yet another thread, im going t build off my original one.
from here i will add any pictures ive taken on the way until now, and any other modifications/upgrades that will be done in the future.
until now:
- add a leaf kit on rear
- torsion key crank
- spare tire carrier
- installed and uninstalled side steps (will re install down the road)
- any other reg maintenance (ball joints, hubs, breaks, shocks, typical blazer problems)
coming up:
- 2.5 rough country lift
- roof rack
- flood/fog lights
- winch
here are some pics, stock height, new leaf, trail plug in placement. side step and tire carrier installed.
Attached Thumbnails 99 4 door blazer-img_20170211_111814082.jpg   99 4 door blazer-img_20170227_175218433.jpg   99 4 door blazer-img_20170319_154823618.jpg   99 4 door blazer-img_20170409_132622201.jpg   99 4 door blazer-img_20170409_142753967_hdr.jpg
99 4 door blazer-img_20170802_183153046.jpg   99 4 door blazer-img_20170802_184223131.jpg   99 4 door blazer-img_20170802_184205713.jpg   99 4 door blazer-img_20170803_094904270.jpg   99 4 door blazer-img_20170802_211417909.jpg
99 4 door blazer-img_20170805_152147162.jpg   99 4 door blazer-img_20170803_095120551.jpg
Old Mar 11, 2018 | 10:57 PM
What did you end up doing to reinforce the spare tire carrier?
Old Mar 12, 2018 | 09:41 AM
I do not have any pictures, but I used 2 pieces of 16g steel, I believe they were 3"x14". I curve it to the body and installed them against the body on the back 2 bolts only. My bolts went through the body and the inner piece aswell coming to around 5"-6" long. And for the two bolts above and below the tail light I did not instal anything.
so far with the full size 235/75/15 AND myself(180lbs) on the carrier while it is open does not warp or bend the body at all. Been a good year since I installed it. I didn' have lock tight when I installed it so I will be re-tightening the bolts sometime this summer. Just for security reason, they haven't comes lose yet
Old Mar 12, 2018 | 10:28 AM
I've been thinking of doing this mod but I've struggled with how to properly reinforce the attachment points. I really like your solution and will use what you did when/if I do this mod.
The only other thing I came across in my searches that I think could possibly improve on what you did is to use an automotive body panel adhesive/sealant to secure your metal bars to the inside of the body panel to further distribute the load.
If you do get in there to to re-tighten the nuts, please take and then post pictures.
Thanks!
Old Mar 15, 2018 | 12:11 PM
Mail lady came in today. Gave me some more parts for the blazer. Now just gotta hit the scrap yard this weekend for:
- 1st gen s10 centre link
- rear calipers
- zq8 steering box
and next Friday I order my lift kit and steering stabilizer. Wife's getting tired of hearing how excited I am lol
Old Mar 19, 2018 | 12:08 PM
Tajohns34's Avatar
I had a knocking like that once. I replaced an axle with a torn boot and found that the 4 little bolts on my ball joint loose. I tightened them and got an alignment and all is well.
Old Mar 28, 2018 | 06:58 PM
FedEx came today. Very happy man. Rough country came threw pretty quick. Ordered on Friday morning, arrived at 3 today. Not bad for travelling from tennessee to Ontario. 2.5 rc lift kit with a steering stabilizer.
I couldn' find a decent 1st gen center link in time so I will be trying out the steering stabilizer that bolts to the second gen. I also picked up these: Steering coupling disk kit and new u joint clamp for the front.
I also did not get the steering box, so I am hoping that the steering stabilizer and new rag joint will take the slack out.
project for Easter weekend:
install lift kit and steering stabilizer
install cv axles
bleed brakes
do tie rods and rag joint
clean carpet in truck
Start assessing rust control to do in may-ish
Old Mar 28, 2018 | 09:14 PM
chevyriders's Avatar
Aw Yeah! Can't wait to see it with the lift on. Should tighten the steering up nice with the stabilizer and new rag joint too.
