99 4 door blazer
Old 11-20-2020, 03:54 PM
So the envoy kept giving today... if it wasn't for the fact that I couldn't get power to the seats before giving up, I would've had those for the wifes sonoma... but ill have better luck comes next season when the yard in the neighboring town opens up again...
  #452
Old 11-20-2020, 03:56 PM
Hadyss's Avatar
I’ve seen a ton of blazers and Jimmy’s driving around here and I know a bunch of them will be in the yard next summer so looking forward to that
  #453
Old 11-20-2020, 06:51 PM
I've seen a bunch around here too...
I forgot that I picked this up for 180 off kijiji... got all the gaskets.... gotta look up the way to bend them, I remember seeing theres a specific way. It was advertised as a new not remand so we will see... either way it was 100 less then Amazon...
  #454
Old 11-21-2020, 07:37 AM
Hadyss's Avatar
Did You get the bracket too? They are different between them
  #455
Old 11-21-2020, 08:10 AM
No bracket, but I'm hoping that since the injector thats in there now came from an 03, that itll work.
  #456
Old 11-21-2020, 08:13 AM
Hadyss's Avatar
The mpfi abs the csfi use different mounts it’s the way they clip on
  #457
Old 11-21-2020, 08:15 AM
Ok so the one in the truck now looks the same as this one. I think I should be good then.. if not, I'll have to take a trip to the yard.
  #458
Old 11-21-2020, 08:16 AM
Offroad King Tut's Avatar
Offroad King Tut is on a distinguished road
I would drop a blown big block in that rollerskate for sure.
  #459
Old 11-21-2020, 08:29 AM
I'm a little lost by this comment...
  #460
Old 11-21-2020, 01:44 PM
So I swapped out the spindle on the driverside, found out the ball joint i was using when I didn't have the proper arms from rc, cause an egg shape. So I have a little play in the new ball joint already, but it'll last until after winter... and I really need to get the upgraded pitman arm, it seems that the new one is poo...
Top is original bottom is from the envoy donor
Quick Reply: 99 4 door blazer
