99 4 door blazer
Old Apr 18, 2021 | 05:15 PM
  #561
Thats awesome. Are you going to make the engine, transfer case and gas tank plates aswell?
Old Apr 19, 2021 | 02:39 AM
  #562
Fatgouda's Avatar
Fatgouda is on a distinguished road
until seeing your all aluminum ones I didn’t even know they had skids that went that far back! Mine has none but I’m hunting them now! I think I stick to the aluminum tho don’t want to weigh her down to much. And I’ve got no template to build them off.
Old Apr 21, 2021 | 06:30 PM
  #563
Picked up a 48" bumper jack for 40$. Couldn't pass it up for that lol
Old Apr 22, 2021 | 11:58 PM
  #564
Hess13x's Avatar
Always carry one of those in my trucks! Nice score.
Old Apr 27, 2021 | 06:19 PM
  #565
These arrived at the store for me yesterday, had to go today as I wouldn't of made it yesterday.
Front and rear n3 shocks upgraded from the blown n2s from the lift kit. And a set of boots for all 4 of them.
Front
Rear
Boots
Speed sticker x2
Old Apr 27, 2021 | 06:26 PM
  #566
Hadyss's Avatar
I went with the blue boots not the easiest to get on the rear shocks though and got 2 extra stickers too
Old Apr 29, 2021 | 06:55 AM
  #567
I decided on black just because of the white and black. And when/if I paint it blue, it'll still go with it.
Fronts were easy, rear weren't as easy. Tried applying soap to the shock to slide on from the bottom, but the boots too hole is too small for that. So I went with this option:
Pushed the pin to one side
Massaged boot slowly over it to not tear the boot. Way easier then i thought it would be
All clamped and ready to go. Hope the rain stops sometime
Old Apr 29, 2021 | 07:33 AM
  #568
Hadyss's Avatar
That’s exactly how I got the boots on my rear shocks as well
Old May 2, 2021 | 01:39 PM
  #569
Replaced rear shocks. Had to remove factory bolt clips that were on the frame, had to cut 1 bolt on each side, and passenger side just sounds on the 2nd bolt. Used heavy duty bolts and lock nuts. Also notice a bad filler neck and vent tube. Luckily it's at thw top and not close to thw tank.
2 hrs later, i think i found the problem...
Old n2's are shot. N3s came good to go minus boots lol. Very happy with thw way they sealed around the "slidder sleave?"
The rubber goes around the sleave as well
Looking ugly with all the surface rust. But shes still solid!
Fronts will be done next weekend or before if I'm not too busy at work.
Old May 2, 2021 | 01:43 PM
  #570
Hadyss's Avatar
Mine were the other way around my rears were still good but the front were shot
