99 4 door blazer
Old Aug 1, 2018 | 09:38 AM
  #61
I haven't heard anything yet, but I will definatly check tonight when I get home! Thanks for the heads up.
Old Aug 1, 2018 | 01:33 PM
  #62
Hadyss's Avatar
It took me forever to figure out why the tie rod was hitting and then looked over the lift instructions and seen I didn’t trim enough. It started hitting after I hit a car that ran a yield sign
Old Aug 4, 2018 | 05:01 PM
  #63
Default My Saturday.
Last photo is the aluminum sheet I used, cut to size and covered the passenger side hole. I riveted the piece before bondo.
Old Aug 4, 2018 | 05:04 PM
  #64
Hadyss's Avatar
Looks like my truck did last winter when I did the bed liner. The black on the bumper pops off to make painting easier
Old Aug 4, 2018 | 07:07 PM
  #65
Yea I know... being lazy... cheap I should say, less surface to cover... lol... I'm gonna have to redo the front when I get the bigger tires. But this way it won't get worst over the winter.
as well I need to reinstall the original door at some point, and I'll have to remove the side mouldings when I do. So might do it proper then... might not... not a show truck so I'm not too worried...
my gfs old s10, I put zr2 fender on the back, fiber glasses them on, then bondo, then painted. Couldnt even tell they were installed afterwards.
Old Aug 4, 2018 | 07:41 PM
  #66
Hadyss's Avatar
If you get any overspray I find brake cleaner works great to clean it up
Old Aug 4, 2018 | 08:52 PM
  #67
11 hours later... 9 hours total of work... maybe less... but she's done 2 coats. And the cans where 2x the thickness... 1 can per coat...
Old Aug 4, 2018 | 09:06 PM
  #68
Hadyss's Avatar
That looks amazing. How much of a lift do you have?
this is mind after painting and installing the new bumper my brother made
Old Aug 4, 2018 | 09:07 PM
  #69
Hadyss's Avatar
After looking at the picture it makes me want to clean mine up and do another coat on it
Old Aug 4, 2018 | 09:20 PM
  #70
I got a 2.5 rough country lift all the way around, and I also have an add a leaf on the rear. Adds about 3" I believe.
