My small 96 Blazer build
#1161
Thanks K!
...The only wierd thing is that I have some binding in either the steering shaft or the box but it only happens really quick when turning without moving so it may just be from trying to turn the large tires and all. It doesn't seem to be a huge issue but I'll spend some time investigating anyway.
#1162
So the center of the bolt from the frame is right at 5" and then of course its 31.5" center to center on the spring mounts. If you need more info on it let me know. Heres a pic of the ranger shackle hanger. I set it exactly 3/4" forward of the body mount bolt and have almost perfect shackle angle with the front bolt 1" in front of that body mount bolt. Sorry its hard to get good pics in there with the back lighting and an iphone
You can somewhat see that I trimmed it to sit parallel to the front hanger and also level.
I'll try and get some better pics if you need them just let me know.
#1163
Thanks man! I am like a little kid with it right now lol!
Thank you sir!
Wow I'm jealous looks good! Earlier I said I hate when SASs have that truck sitting on top of tires look but yours doesn't have that look. When you put the ZR2 flares you mentioned on it'll look even nicer since ZR2s have slightly bigger wheel wells. Once again it looks great!
Thank you! Yeah I'm pretty happy with how it came out as far as not having a roller skate look. The front will likely come down a tiny bit more yet which will help even more. I really need to find some Z flares though mostly for my own ocd with the look. I'll get them eventually tho so for now I'm just happy to be driving it!
#1164
Yeah I'm not sure 100% what it is for sure. Its nothing huge or alarming just a quick slight pop so I'll keep an eye on it and see if something shows from it. I really need to get some shocks on it asap. The boat feeling isn't pleasant and make my butt pucker occasionally lol!!
I put about 10 miles on it today and it drives awesome. I got it to about 55 and it drives straight with no sounds or vibes. I do have some vibration when I accelerate hard from a stop which I am sure is the axle rotating and throwing the pinion angle to s***. I will be looking for some 56's in the near future to swap in for sure. Other than that so far so good!
#1165
What's your plan for the rear tire carrier? I notice you already got it off at the moment lol.
#1166
I'm going to mod it to work with the h2 wheels. I've got a 5th wheel sitting here for it.
#1167
Thank you Rex for the measurement and hanger pics. That was exactly the info I needed.
#1168
Glad I could help
#1169
#1170
Started on my new roof rack today. The mounts are finished just have to add a couple cross bars and throw some paint on it and I can finally put my Surco rack back on there! It's 1 1/4" square 11ga so I think it will be plenty sturdy unlike the factory plastic turd. The feet are 1 1/2"x1/4 and it'll have big fat washers on the backside so it won't pull through the roof. So far besides the fact I couldn't seem to put down a decent looking weld today I'm really happy with how it's turned out. Here's a couple pics.
The large hole in the left foot is for my roof light wire harness to pass through.
And so far it's only cost me $33 for the steel and then few bucks the stainless hardware is going to cost.
