Project: Silver Fox
Old Aug 8, 2011 | 11:20 PM
  #31
84BlazerS10's Avatar
Looking good.
Old Aug 8, 2011 | 11:30 PM
  #32
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Originally Posted by Brian_D
did you make that dash plate for the cd player?
If so please tell me what you made it out of
Metra Universal ISO Double-DIN Turbo Pocket Kit - Metra 999999
i spy a ses light =( our worse enemy
Key is only at light test notch, not started! he he, but good eye!
Old Aug 8, 2011 | 11:43 PM
  #33
Thogert's Avatar
Originally Posted by Ugly_Monkey
Close call!
Naw, plenty of room!
Glad I got the easy-over on the antenna now!
Haha, I got about that close to the top of a parking garage once, and I don't even have a lift. Although with my lights and the lightbar, it's about 10 in. taller than the roof but still. Lookin' good though.
Old Aug 9, 2011 | 12:12 AM
  #34
dallas1's Avatar
dallas1 is on a distinguished road
Thumbs up
good looking ride.
Old Aug 9, 2011 | 12:59 PM
  #35
Default Planning: OBA Install
Originally Posted by dallas1
good looking ride.
Originally Posted by 84BlazerS10
Looking good.
Thanks guys! Next install will be the onboard air!
VIAIR continuous duty system:
Fittings, filter, and hose!
I am planning on mounting the tank above the rear differential, but that is as far as a have gotten in my planning!
Old Aug 9, 2011 | 08:15 PM
  #36
killallblue's Avatar
killallblue is on a distinguished road
looks good what wire power wire did u have the cb on
Old Aug 10, 2011 | 11:53 AM
  #37
TheRandom1's Avatar
What did you use to be able to tip over the CB antenna like that? I'm looking to do almost the exact same thing on mine.
Old Aug 10, 2011 | 03:28 PM
  #38
Its called an "easy-over". I got 2 off amazon a while ago. Cons are: shouldn't be used to transmit when folded down, and the pin in the center may fall out so zip ties should be used to "leash" the antenna whip just in case.
Old Aug 10, 2011 | 03:56 PM
  #39
TheRandom1's Avatar
I was considering using something similar (I'll go look on Amazon) but with a clip towards the top of the antenna where it meets the roof rack. Have you had any other issues with the antenna flopping around while it's down?
Old Aug 10, 2011 | 05:05 PM
  #40
The device goes between the antenna and the spring, it wont work any other way due to the sliding action it uses to operate. My antenna is on the lower bar on my basket, the fold is about six inches up from the mount. So it folds over and lays on the top bar up front. I sliced up some 6" lengths of 3/8" fuel line and zip tied them to the bars to protect the antenna from flopping around. For now I just used a reusable ziptie for holding down the antenna, and I insert a paperclip through the easy-overs pin and wrap it around to be sure it does not fall out.
In the upright position it will not affect your SWR, HOWEVER FOLDED OVER IT WILL CREATE A HUGE SWR!!! Don't damage your radio!
I had it running on a regulated splitter. I got a coil/capacitor RF choke diagram from a Radio Engineer so I just need to build it. Then I will power the CB through the choke but from my rear battery that i still need to install!
