Project Sleeper Blazer
Old Oct 9, 2017 | 07:58 PM
  #51
Tajohns34's Avatar
It sounds really good.
Old Oct 9, 2017 | 09:39 PM
  #52
ChuckNTruck's Avatar
Thanks!
i need to get the tune dialed in a bit more because im very rich on the top end. I think once i get it dialed in ill jump my shift points a little bit higher to around 6000-6200rpms.
I really should put it on a dyno and see where my power curve is because this thing wants to keep pulling through the rpms.
Old Oct 19, 2017 | 10:08 PM
  #53
calereeves's Avatar
calereeves is on a distinguished road
Nice work! I've got a ton more room in my k5, but I'm considering swapping a spare 5.3 for the 350 that's already in it. Love that you kept a/c
Old Dec 6, 2017 | 12:33 PM
  #54
marty68's Avatar
marty68 is on a distinguished road
revive an old thread ... I am curious. does the blazer trans work with the 5.3? same wiring same plug?
Old Dec 6, 2017 | 12:37 PM
  #55
marty68's Avatar
disregard lat post. I now see original trans was a 5spd.
Old Feb 18, 2018 | 10:48 AM
  #56
BossToneKC's Avatar
BossToneKC is on a distinguished road
Originally Posted by ChuckNTruck
Thanks!
Hey! I’m new to the forum and I have a 2003 Blazer. Best thread I’ve seen on a swap so far!! Wanting to do the same build but curious about the budget 🤔. My 4.3 been leaking coolant it seems like from everywhere so it’s time for a update.
Old Feb 18, 2018 | 06:51 PM
  #57
Originally Posted by BossToneKC
Hey! I’m new to the forum and I have a 2003 Blazer. Best thread I’ve seen on a swap so far!! Wanting to do the same build but curious about the budget ��. My 4.3 been leaking coolant it seems like from everywhere so it’s time for a update.
Nice blazer, i love that color!
The swap itself cost me about 6k including the engine and transmission. The cam swap alone cost me about $800-$1k because i upgraded the cam, lifters, push rods and valve springs while i had it apart.
Im about 9-10K into my build now including the $1200 i paid for the blazer itself, the Detroit Truetrac limited slip diff and i also replaced all bushing and bearings in the entire suspension and drive train with the exception of the pinion bearings.
The last thing i need to do is have a trans built properly and a higher stall converter. It runs good right now but the current converter is way to tight for the cam.
Old Mar 15, 2018 | 10:01 PM
  #58
Finally got tired of the lazy shifting stock 4L60E so i had one built along with a FTI 3200 stall Billet converter. Got the bell housing and tail shaft swapped from a spare trans i had laying around but i kinda wish i would have painted them to match the trans case. Oh well, Hopefully I will get it swapped tomorrow.
Old Mar 20, 2018 | 11:29 PM
  #59
twiggss's Avatar
twiggss is on a distinguished road
Nice build!
I've read on some swaps that mods have to be done to the A/C box. Looks like you were able to avoid that?
Old Mar 21, 2018 | 10:39 AM
  #60
Originally Posted by twiggss
Nice build!
I did not have to modify the A/C box at all.
But i highly suggest removing it when installing the engine because i did crack mine by accidentally bumping it.
