Project Sleeper Blazer
#72
I love this thread. Thank you. Fantastic job.
I have two 2002 Blazers with the 4.3. First is an LS that I built for my son. The second one is an Xtreme I just picked up for a couple hundred dollars and I am highly considering doing the swap to it since I'm in it relatively cheap. It needs a bunch of repairs but most are minor. Considering doing a thread on it as I go.
Aside from the info in the thread, do you have a list of everything you had to do? I have a ton of questions but don't want to clutter your thread.
#73
#74
Finally got to a local Plastic supplier and bought some sheets of 1/8 ABS plastic to recreate my airbox. This will be another experiment to see if it can keep the IATs down and for $30 worth of plastic and a couple hinges i figured id give it a shot.
#76
I checked it while just revving up in park, but with my poly engine mounts the engine does not move much unless under heavy load.
Hopefully ill get some time tomorrow to take it out and beat on it a bit to make sure nothing will rub with the engine under heavy load.
My old metal box had about the same clearance and never had any issues though.
#78
you can just barely see the O2 sensors in this picture. they are tucked up near the engine due to the limited space. I have modified my exhaust some since this picture to run a 3in pipe all the way up to where the dual pipes come together and added an exhaust cutout for when i go to the track.
#80
Still running great and still my daily driver. I have about 8-9K miles on it since the swap. It sat for about 8 months this summer when i deployed, but started right up when i got back. I always stabilize the fuel, change the oils and have the battery on a trickle charger when i leave.
I also have a LSA supercharger kit on order for it. So that will be my winter project as i will have to build the entire fuel system and modify a few things under the hood to make it fit nicely and still look as factory as possible.
