To resurrect or not to resurrect, that is the question!
Old Nov 12, 2013 | 06:00 PM
  #51
newguy's Avatar
Yes the thicker ones are the power wires
Old Nov 12, 2013 | 08:46 PM
  #52
Dark Rider's Avatar
Dark Rider is on a distinguished road
First, invest in a Chilton or Haynes manual if not already done.
Second, I'd still defer to my first post about changing all of the little things (plugs, wires, cap & rotor)
Your problem ultimately is in one of three places: 1) fuel, 2) air, 3) electricity.
Seeing how it briefly started when you sprayed stuff into the throttle body, I'm still thinking fuel... Your injectors, after sitting for so long, may have become clogged. IDK for sure. Something (rust, dirt) coulda shot through the gas line when the fuel pump and filter were changed out and then primed again. But if I really wanted to get this thing working I would change the plugs, wires, distributor cap and rotor, and test the selenoid. I would also go to an auto store and rent a computer scanner to see if your shooting codes. Your MAF sensor may be bad (example not rec.).
Old Nov 12, 2013 | 10:33 PM
  #53
hey_j00de's Avatar
hey_j00de is on a distinguished road
WELL the new fuel pump works. There's fuel pressure. Mission accomplished.
1 down(fuel), 2 to go (air and electricity). I'm going to check the distributor cap and wires tomorrow. I'll need the special tools for getting the plugs out so that may take me awhile, hopefully they're not the problem since there's only 44k miles on the thing... wish me luck!
Old Nov 19, 2013 | 05:26 PM
  #54
hey_j00de's Avatar
IT LIVES. The new distributor cap and rotor did the trick. THANKS SO MUCH for all your guys' help. I really appreciate it.
Chadoo951
13
Jun 30, 2010 01:59 PM
wayland
Dec 9, 2009 12:38 PM
Boiler_81
Dec 2, 2008 10:04 AM
96Ls4Dr
Oct 26, 2008 04:45 PM
Thor_449
May 26, 2008 12:00 PM
