Rough Country 2.5" Lift!!!!
Old Nov 24, 2011 | 06:54 PM
  #141
Mike98Blazer's Avatar
Originally Posted by neo71665
Guys its only designed as a 2 inch lift, its not a 5 inch cradle that drops the front diff way down. There isn't much room to drop the front diff before you are rubbing the axles. The little bit will help but still imho worthless when the sfa kit isn't much more and you get way more from it.
I built my sfa kit and only have $50 in it. Add 100 for a dana 30 and 100 for springs if you have the stuff its much cheaper. The limited market of parts for a series that is out of production is gonna keep the prices high and the companies willing to design parts for us limited. Sometimes you just gotta take what ya can get or forge your own path.
Question for ya, I've been thinking about doin a sas, what did you do about abs? If you got rid of it how did you eliminate it from throwing a code (In PA if there's any active codes in the computer it fails inspection no matter what it's for)
Old Nov 24, 2011 | 10:28 PM
  #142
neo71665's Avatar
87 bud, no abs on mine. Heck we dont have fender laws or sniff tests. I only have to keep my headlights below like 54 inches or something like that.
Over on s10forum they have the measurements for a ring that allows you to run the s-series bearing hubs. This allows you to keep your abs and wheel bolt pattern.
S10 unit bearing to XJ Knuckle adapter ring - S-10 Forum
Other than that you just need somebody to remove the abs from the ecu. If ya want more infor on sas swaps on a friendly forum I suggest checking out s10extremist.org. Most of the same guys as s10forum but the maturity is higher over there.
Old Nov 25, 2011 | 03:29 PM
  #143
Ne s10 blazer's Avatar
Ne s10 blazer is on a distinguished road
Originally Posted by rhino420
would i still be able to tuck 31's under the back? Right now im running stock 235/7515 but i really want to run 31x10.5 15 in the back and the front and I know I wont have a problem in the front because I'm getting fiberglass front fenders and hood similar to this s-10
below ( this one is way more advanced then what im doing)
I have been looking all over for fenders like that where are you going to get them from?
Old Nov 25, 2011 | 04:39 PM
  #144
rhino420's Avatar
rhino420 is on a distinguished road
Prerunners - Woolworth Motorsports
this place has them but There is a local place around me that im getting mine done at. Ill see if they can ship and get back to you.
Old Nov 25, 2011 | 05:01 PM
  #145
Benedict1337's Avatar
you can fit 31's in the back at stock height
Old Nov 25, 2011 | 06:23 PM
  #146
neo71665's Avatar
Never delt with one with a saggy butt have ya, lol
Old Nov 25, 2011 | 06:30 PM
  #147
xgiovannix12's Avatar
lol saggy butt sounds weird
Old Nov 28, 2011 | 05:55 PM
  #148
Xb-lineblazerX's Avatar
Xb-lineblazerX is on a distinguished road
any other in-expensive lifts you guys know of? sounds like this new RC one isn't so reliable. suggestions for different lifts that aren't $100,000.. or details about how you made your own??? (shackles, brackets etc..)
Old Nov 28, 2011 | 06:50 PM
  #149
Old Nov 28, 2011 | 08:36 PM
  #150
neo71665's Avatar
Without the drop brackets you can crank the factory front end (Limited to 1.5 inches) and do the same exact job as the keys. Save your money.
Shackles are 2 inche for every one inch of lift.
Ex. Say the stock shackles are 3 inches center to center of the holes making a set that is 5 inches center to center will gain one inch.
