Dirt in the fuel is a killer
Old Sep 12, 2006 | 04:49 AM
Chevy Lover's Avatar
Default Dirt in the fuel is a killer
OK, I know that 99% of you guys are fuel injected, but dirt in the fuel has the same effect in carbs as in injectors.
For the last month I've had problems getting my engine started. I've had to crank it over longer and play with the gas pedal.
Today I got fed up and pulled aprt my carb. If you look at these pictures, you'll be amazed that it even ran.
Anyway, I cleaned out the dirt and replaced the float, needle and seat and the gaskets. I'll put it back on tomorrow and I bet it'll run 100% better.
[IMG]local://upfiles/2910/FB25CA8E6A1D4075B1F32229A9D36A68.jpg[/IMG]
Old Sep 12, 2006 | 09:06 AM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: Dirt in the fuel is a killer
ick!
btw, carbs rule. FI is for pansies
Old Sep 12, 2006 | 09:14 AM
How much of that junk was down in the bowl?
Man I remember the first RQJ that I ever pulled apart. Playing with metering rods in those things was fun... Nothing like tuning a Holley though. Holley's are just more predictable. When I got the chance to switch to a Holley 650 DP on my Chevelle, I jumped at it! $100 for the carb and Edlebrock Torquer II intake!
Old Sep 12, 2006 | 02:01 PM
IdidNOTdoIT's Avatar
IdidNOTdoIT is an unknown quantity at this point
That, my friend, is why I decided to go gasless, carburetorless, and spark-plugless 8 years ago. That mess can drive you crazy at times. I've had the same problem down in an old Q-jet I had. Good running carb though when she's working right, huh?
Old Sep 12, 2006 | 07:53 PM
Blazin_Jason's Avatar
Chevy Lover - Where do you get your gas?
Old Sep 13, 2006 | 01:48 AM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
out of an oil well...literally. the gas is usually black, better for black smoke, right?
Kknd310
Nov 8, 2011 05:39 PM
Bushblazer
Jul 3, 2011 09:21 PM
Bielat16
Dec 25, 2010 09:40 AM
Bielat16
Oct 3, 2010 09:35 PM
redneck2725
Tires and Wheels
Jun 30, 2008 04:40 AM
