engine options??????
Old Jun 5, 2006 | 12:56 AM
rcravincase's Avatar
rcravincase is an unknown quantity at this point
Default engine options??????
does anyone know if there was ever an s10/blazer/jimmy etc that had the 3.8 liter in it? ive got a project idea in mind, and it would be great if i could find a rwd gm vehicle with the 3.8 liter so i can use the rear axle and tranny. my plan is to cut up my geo tracker, stuff the 3.8 liter into it, supercharge it, and make it a corvette and fox body mustang killer. if there arent any 3.8 liter rwd gm's, is there a tranny that will bolt up so i can use the 3.8 from fwd cars?
Old Jun 5, 2006 | 01:11 AM
Default RE: engine options??????
The problem with using a FWD 3800 is the motor mounts... Or lack of side motor mount provisions.
The late 90's camaro is the only RWD GM that I can think of that came with the 3800. You should be able to use a RWD block, and build it up with internals from a supercharged L67 3800 S2 (rods/pistons/crank), use the L67 heads/intake/supercharger... The difficult part is going to be controlling the motor. The PCMs are integrated engine/transmission control units. I can only guess that the transmission control would be different between the rwd 4L60E and the FWD 4T65E-HD behind the series 2 L67.
If you want to know more about this, there are many good websites:
L67Swap.com
3800Pro.com
to name two...
Good luck and sounds like a damn good project. I know that one of the members on BonnevilleClub.com took a S2 3800 L67 motor/trans and installed it into an '89 or '90 Bonneville SSE with completely integrated electronics and very impressive performance.
BTW, my other vehicle is a '01 Bonneville SSEi with the supercharged 3800.
Old Jun 5, 2006 | 10:40 PM
thanks for the help. im hoping to find a car that is mainly intact so i can rob it of the computer controls. what would it need with the computer if i were using a manual transmission (i dot like auto's)? im going to look up on painless wiring if they have a wiring kit for these engines
Old Jun 7, 2006 | 05:43 AM
SniperX13's Avatar
SniperX13 is an unknown quantity at this point
ouch, all that in a tracker..... with that narrow and short of a wheelbase, would it be controllable with all that power?
Old Jun 15, 2006 | 12:21 PM
i dont know if it will be controlable, but im thinking of making a wheelie bar if i supercharge it.
i also found the donor vehicle i will need. late model (98-02) base model camaro. im sure i can get a wrecked one for around $1k. then ill have the engine, engine management and computer, tranny, axle, and whatever else i might need
Old Jul 2, 2006 | 01:40 AM
drifts14x's Avatar
drifts14x is an unknown quantity at this point
Depending on how skilled you are, and how much "hacking" you wanna do to that tracker, I suggest a 5.7 V8, it would go really fast, and be very much unexpected on the street. That's probably the best way, and man, that would be tough as hell. Otherwise, why not get a 4.0L V8 from a Toyota SC400, as those are already quick, and would be a great small motor that'd probably fit more easily in that Tracker.
Old Jul 4, 2006 | 12:15 PM
johngmysticnotions's Avatar
johngmysticnotions is an unknown quantity at this point
What about a grand national. That was a RWD 3800 then with the turbo.
But like was said earlier. Its all about the dollar$.
John G.
Old Jul 4, 2006 | 12:51 PM
02 Vortech's Avatar
02 Vortech is an unknown quantity at this point
guy on s10forum with a turbo 3.1 that he stroked to 3.4L runs 13.1 in the 1/4.
Old Jul 5, 2006 | 12:11 AM
a v8 would be too long to fit in the compartmant without cutting out the firewall, which is the main strong point in this vehicle. a gnx engine would cost too much, a lot of people around them still use them
Old Jul 5, 2006 | 08:14 AM
ORIGINAL: rcravincase
Simply not true. People drop v8's into s-series vehicles all the time. And all without massaging the firewall. I am actually researching the electrical/controls aspect of putting a SCFI 350 into my Bravada. Making the motor fit is the least of my worries.
88s10Blazer
Jun 28, 2010 12:36 AM
blrob5
May 3, 2010 08:22 PM
jimmyeatworld
Apr 15, 2008 08:06 PM
revisednut
Jan 29, 2008 10:11 PM
94BlazerFORSALE
Engine & Internal
Nov 13, 2006 12:36 AM
