engine swap
Old Apr 10, 2007 | 06:47 AM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: engine swap
yes, the 305 and 350have the same outside dimensions.
Old Apr 11, 2007 | 05:06 PM
bigblaze85's Avatar
bigblaze85 is an unknown quantity at this point
cool, thanks man
Old May 20, 2007 | 06:07 PM
bigblaze85's Avatar
does anyone know if when i swap then engine if i need to change the driveshaft and if so what driveshaft will work?
Old May 21, 2007 | 01:35 PM
mojoman13's Avatar
mojoman13 is an unknown quantity at this point
i will tell u in a bit
installing my 350 this up coming weekend and ill tell ya what needs to be done to fit er in there
Old May 21, 2007 | 02:55 PM
Blazin_Jason's Avatar
Well depending on how you mount the engine, what trans you run will depend if you need to mod the driveshafts. I put my engine and tranny in so that the tranny was in the stock location. So I will be able to run the stock driveshafts (4x4). Usually with a 2wd people shorten the shaft as they set the engine back.
gmoney30
Jul 5, 2010 08:51 PM
SureShooter29
Mar 18, 2010 03:02 PM
gmoney30
Jan 22, 2010 07:07 PM
ronnyrum1
Engine & Internal
Dec 11, 2005 11:34 AM
billybird
Jul 20, 2005 11:17 AM
