please help code p1345
Old Jul 21, 2010 | 08:53 PM
b77dougan's Avatar
b77dougan is on a distinguished road
Originally Posted by gmclowsierra
you say you rebuilt the bottom end. what did you have done. did you put the crank reluctor wheel back on? and is the nut that holds that tight? had the same thing happen on jasper reman except it ran for aprox. 3 months then died. no spark. found crank reluctor ring loose and not turning with the engine.
will check inn the am thanks for the idea
Old Jul 27, 2010 | 06:52 PM
b77dougan's Avatar
can i change the timing cover why it still in the truck or does it have to be pulled out thanks
bakalo0323
35
Mar 24, 2013 08:45 PM
Klturi421
Sep 25, 2012 08:13 PM
Alex98Blazer
Aug 24, 2011 10:18 PM
dirty420
May 29, 2011 10:15 AM
jonny22107
Jan 25, 2010 11:49 PM
