1996 s10 blazer overheated!?
Old Nov 27, 2008 | 01:47 PM
caddy500's Avatar
caddy500 is an unknown quantity at this point
Default 1996 s10 blazer overheated!?
Looking at a 1996 s10 blazer vinWthat overheated. Now it makes a knocking sound. What usually causes these things to overheat? and what would cause the knocking after overheating it. Can't seem to tell exactly where it's coming from.
Thank you, Caddy500
Old Dec 4, 2008 | 02:50 PM
rattosh51's Avatar
rattosh51 is an unknown quantity at this point
Default RE: 1996 s10 blazer overheated!?
There may be a fewthings causing overheating, bad thermostat, radiator or head gasket.
Is there any coolant in the oil? White smoke out the exhaust?
Old Dec 4, 2008 | 04:52 PM
salvy's Avatar
salvy is an unknown quantity at this point
Leaking intake gasket, not checking coolant, bad radiator head gasket, ect.... The knocking is a result of the overheating, probably a spun bearing, threw a rod, cam bearing, ect.. Not good ! Check your oil,is it like a chocolate milkshake? If so probably a head gasket. Good luck.
ronaldo
Jul 25, 2011 09:34 PM
ahlinebe
Nov 27, 2010 07:05 PM
Blazer1999ls
Jul 16, 2009 12:05 AM
78Special
Jan 5, 2008 07:20 PM
ivannj
Feb 15, 2006 12:20 PM
