2002 Blazer engine and transmission compatibility
I have a 4 door mid 2002 Blazer, motor is without the egr. I also have a 2 door 2000 Blazer, motor has the egr. My question is, can I swap the motor and trans from the 2000 to the 2002? Will they fit directly or need modified? Also, could I just cap off the egr port in the 2000 engine to make it work with the 2002's computer? Thanks in advance for all answers and input!
As an aside, another good reason for switching the manifolds is the A.I.R. system piping attached to the front of your exhaust manifolds for your 2002 may be quite different. Whatever you had from the factory needs to be kept or the PCM will know and turn on the SES light.
https://www.eficonnection.com/home/p...e-knock-sensor
ruditron
11-30-2009 11:38 PM
