2002 Xtreme wont hold fuel pressure
As long as the ball valve is open, and fuel can pass through it, there should be fuel pressure at the service port.
With the ignition in the OFF position, connect a jumper wire from battery positive to the fuel pump prime terminal in the underhood fuse panel.
When the fuel pressure stabilizes, it should be 60psi to 66psi. Remove the jumper and pressure must remain above 55psi for at least 10 minutes. Post your results.
That is borderline fail on both tests. It's not enough to cause a stall or hard starting, but if it gets any worse, it's a problem. Modify the pressure tester to connect directly to the ball valve that you installed. All pressure and flow must end at the tester. Open the ball valve and jumper the pump, with the pump running, pressure must be 73psi tp 108psi. It must remain above 55psi for at least 10 minutes after you remove the jumper wire. Post your results.
Hey everyone just want to post that my 2002 extreme is fixed, if you can belive this it was the cap and rotor {even thoe it had spark before i replaced it} bought a brand new one and it run like brand new thanks for all the help if can help any one feel free to message me. thank again for all the help.
Jamesrp7
Feb 9, 2013 11:43 AM
ABSLT
Aug 31, 2012 11:46 PM
skidud
Sep 8, 2010 08:54 AM
strongboy2005
Feb 20, 2006 02:36 PM
