2003 S10zr5 desnt have 3rd gear
Old Jun 14, 2021 | 01:04 AM
Wpointer357's Avatar
Wpointer357 is on a distinguished road
Default 2003 S10zr5 desnt have 3rd gear
I have a 2003 zr5. It goes into neutral instead of third gear. I've replaced both selinoid inside the tranny but it still isnt fixed. I've been reading but cant get a clear answer on this issue. I need help to figure it out. Please
Old Jun 14, 2021 | 09:47 PM
You could have a worn out 3/4 clutch pack. This is not an uncommon failure mode for the 4L60E.
Does the transmission shift from first into second just fine but then when it would upshift to 3rd does the engine rev instead? If yes, then a worn 3/4 clutch pack could likely be the problem.
If this is the problem, then a transmission rebuild or replacement is the only solution.
Old Jun 17, 2021 | 04:23 AM
This is the first time a transmission replacement has been suggested. Yes first and second are fine when it goes to third it revs up as if in neutral. Time to learn how to rebuild a transmission I guess.
Thank you for your time.
Old Jun 17, 2021 | 10:08 AM
I take no pleasure in suggesting that a rebuild is needed. Have you taken it to a transmission shop for a diagnosis?
LesMyer
Feb 5, 2016 07:32 AM
CraigSnedeker
Jul 8, 2011 09:44 AM
kellysmith
Dec 9, 2008 08:06 AM
numus
Aug 21, 2008 03:10 PM
Blazer man1998
Apr 15, 2007 02:16 AM
