4.3L Vortec Getting a Rebuild
Old 05-24-2022, 12:40 PM
LesMyer's Avatar
LesMyer will become famous soon enough
Originally Posted by reway
Thanks Les, I think it is the mounts making a lot of the difference too. I took it on a 200km round trip road trip and camping for a night and it's doing great! Fuel trims are perfect all across the board it seems like it's running great. I'll also mention I have found no leaks at all, my engine is still all clean! SES light came on soon after the road trip but not to worry it's the annoying P0420 that has been haunting me ever since I drove around with a bad spider for too long...(a year and a half ago) I think I will just cut my cat out next weekend and put some spark plug non-foulers in to eliminate the light, but that's a discussion for another day, and another thread. Thanks again Les, I still can't believe every time I go to start it that it actually starts and moves under its own power with all those parts I put in it! I have learned so much here from you and I can't thank you enough for that.
I am still amazed after many years how well all the parts of an engine work together and at the speeds that they do. Cruising down the highway at only 2000 rpm in OD, each of the 6 cylinders is firing around 17 times/sec. Each of 12 valves are opening/closing and each spark plug is firing at the same rate - all in near-perfect synchronization (not to mention injection of a precise amount of fuel just before each cylinder fires. To hold the parts in your hand and put them back together into a working engine gives you a much different perspective. It also can be a big source of pride that few understand, and strangely can make you like your vehicle a lot more. You did a first rate job fixing this one.
I personally can't recommend the non-foulers to attempt to circumvent having a catalytic converter. Don't really see how they could truly work, anyways - doubt if they really slow down the O2 sensor response time so much that the PCM thinks there is a converter present retaining oxygen (during the tests that it constantly does). But admittedly I've never tried it. I always thought of using the non-foulers as being a form of Urban (Internet) Legend that has been spread without merit. Once a poster thinks they fixed something, they are unlikely to post another time admitting they were wrong - so it gets propagated as being valid. I never thought it made any sense, so I ignored it. (Just like many popular fixes start by replacing O2, or crank, or MAF sensors - because replacing them "fer sure" fixed someones vehicle)
  #282
Old 05-25-2022, 04:45 PM
reway's Avatar
reway is on a distinguished road
You couldn't have said that better Les, it's a totally different feeling driving something around that you put together yourself. Thanks for this information about the non-foulers, I looked into it a bit more and it seems for some people the SES light does come back after a while. I'm not sure what I'll do now but I'll figure out something to keep that P0420 away, a new cat is just so expensive especially since we don't have any emissions checks here ever. Thanks Christine, lol I need that better mileage right about now. My other car that I was driving has a 2.5L inline 6, compared to the 4.3L V6 it was practically free for gas!
VotiveFire
03-12-2021 10:30 PM
Small Arms Collector
09-11-2020 12:06 AM
turbo12b
08-13-2010 11:49 PM
AlaskanK5
01-13-2010 07:05 AM
BVFD25
09-01-2009 03:53 PM
Quick Reply: 4.3L Vortec Getting a Rebuild
