79 Blazer. Brand new 350 engine. Lacking power
Old May 28, 2019 | 07:22 PM
Jack Arpert's Avatar
Jack Arpert is on a distinguished road
Default 79 Blazer. Brand new 350 engine. Lacking power
Recently the engine doesnt seem or sound to be getting enough power between 5-40 mph before kicking (with a significant jolt) into 2nd. I just put this new engine in, bought from chevy dealer, after blowing out the old one. had to drive it immediately from utah to canada after the work was done. ive checked all the fluids several times since the long drive and added more transmission fluid. the pickup on initial acceleration is lacking and obviously not working properly from the sound and feeling. any tips would be greatly appreciated
Old May 28, 2019 | 09:12 PM
cleburne red's Avatar
Maybe check the timing?
Old May 28, 2019 | 09:55 PM
odat's Avatar
5 to 40 mph before it shifts to second sounds more like shift points are too high not lack of power - THM350 is a detent cable, THM400 is a TV cable both reset the same way - push the center metal pad in, slide inner shaft in then do wide open throttle and it will set shift points - picture of cable .....
Old May 28, 2019 | 10:11 PM
Thought the first trans wirh TV cable was 700R4? Isn't the TH400 still detent cable?
Old May 28, 2019 | 10:25 PM
odat's Avatar
Originally Posted by cleburne red
Thought the first trans with TV cable was 700R4? Isn't the TH400 still detent cable?
Edit ... I stand corrected A standard TH400 uses a electric kick down switch on the throttle linkage that powers a electric detent solenoid on the valve body - The TH200R4 has a TV cable and is pressure control as with the TH700R4
If the electric switch on the throttle linkage is way out of adjustment it can be the same as a TV on the TH200R4 / 700R4 or a detent on a TH350 if way out of adjustment it will hold the shift points off and too high .....
Old Jun 1, 2019 | 08:17 PM
Randy Jones's Avatar
Randy Jones is on a distinguished road
well wonder if you put in a new fuel filter?? since stated a new motor ?
Dkarll88
Oct 15, 2018 06:27 PM
dobyken
May 31, 2016 09:31 PM
K5Rookie
Oct 5, 2012 07:32 PM
oisinirish
Jan 30, 2011 02:49 PM
rdhack
Feb 17, 2009 08:46 PM
