'86 K5 Ported Vacuum Switch and EFE
Upon some extended "spaghetti" sorting under the hood and routing all vacuum lines per the diagram I am finding that at any temperature, hot or cold, there is never any vacuum to the heat riser/EFE, well once for about 1/2 a second at operating temp,. It appears to be a normally closed valve which obviously will cause issues upon reaching operating temp. The line comes from a "Ported Vacuum Switch", OEM#3055378, which also sends vacuum to the thermac "flapper" and the vacuum advance.
Has anybody else had this issue? And could it also be affecting the thermac itself as I am getting vacuum from both tubes that run from the "Sensor" inside the air filter housing. I tried switching the lines and the thermac closes in either setup.
Thanks in advance.
Thanks in advance.
cjb2145
18
Oct 6, 2018 04:46 PM
altoncustomtech
Jan 5, 2012 07:40 PM
scott_wheels
Headers, Intake, & Exhaust
Sep 8, 2010 06:15 AM
antything2
Oct 5, 2009 09:15 PM
