96 4.3 blazer eating coolent
Old Oct 28, 2012 | 11:35 AM
June's Avatar
June is on a distinguished road
Default 96 4.3 blazer eating coolent
It's not leaking outside the blazer.. I put 1 gallon in it because I wasn't getting any heat thought it was the thermostat, opened the cap I see no coolent. Ok after I add the gallon I get heat radiator is full or so I think... after 5 miles of running again NO heat and now it's running at about 230 and telling me to check gauges.. I have since put in 2 more gallons.. it's not leaking outside on the ground... I went out and looked and theres now again room for more coolent in the radiator... Any suggestions would be great!
Old Oct 28, 2012 | 11:46 AM
warthogdriver's Avatar
I hate to say this but if its not going on the ground its in the engine in places it shouldnt be.
Check your oil asap....i am guessing its gonna look like milkshake. You may have an lower manifold intake leak. The longer you run like this the more damage your doing.
Old Oct 28, 2012 | 12:33 PM
June's Avatar
yep your right, just got off the phone with my brother in law.. I told him I have a milk shake on my dipstick. we figured head gasket.. I'll pass along your suggestion of the lower manifold ..... Thanks for your input!!
Old Oct 28, 2012 | 12:57 PM
rriddle3's Avatar
If you're not blowing white smoke out of the exhaust, it's a big time lower intake manifold leak. Fix it ASAP.
Old Oct 28, 2012 | 01:08 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Troubles
I know GM has several bullitins (pardon my spellin) about this problem.Its even worse with new models and the V8`s.They should have had a recall instead of making owners pay the cost out of their pockets.I guess supposedly changed the gasket design to fix the problem.
95BlackGA
Nov 17, 2011 10:55 PM
megaroos_00
May 4, 2010 06:39 PM
nonblazing4x4
25
May 28, 2009 05:00 PM
EuroGoldLS
Street N Strip
78
Apr 11, 2008 04:06 PM
