96 s10 4WD Trans bumping
Hello, i got a 1996 S-10 4WD Chevy Blazer, the transmission shifts real hard from 1st to 2nd...It does like if it would wait to long to shift then shift real hard...i changed trans oil but it havent help... any ideas? Thanks
And this is an automatic trans btw.
you got engine troubles?
If the tranny only acts up from 1st to 2nd it could be a sign of engine troubles. Or it could be a shift kit. Does it do it at all rpms, like under light peddle, moderate peddle, and heavy peddle, or when?
1-2 shift solenoid valve going bad maybe?
thanks for your answer but the motor is crap...gotta change it
2kblazerunknwnprblm
01-01-2014 01:32 PM
BIG IRON
05-30-2013 07:33 PM
Adrienne3889
02-22-2012 12:50 PM
