97 4x4 multiple issues
Old Oct 5, 2012 | 07:35 PM
acremeans2326's Avatar
acremeans2326 is on a distinguished road
Default 97 4x4 multiple issues
I have a 97 Jimmy, and I'm having a couple of issues. Main issue is that I only have 1st and 2nd while driving. It will not shift to 3rd/4th. If I'm in Drive, then it won't shift out of 1st. When the trannys cold, I also don't have Reverse, I have to drive around for a little bit before it will kick in. The Reverse issue actually started first, but it wasn't a big deal until now I can't drive about 25MPH. Not sure if it's related, but my 4x4 will not engage either. If I switch to 4L, it sounds like it's pulling hard, but the front wheels are not pulling.
I've been told that it could be shift solenoids, and an actuator for the 4x4. If it's just going to cost a couple hundred in parts, I'll do it, but I don't have the $$$ to do a rebuild.
Any helps appreciated
Old Oct 5, 2012 | 08:18 PM
warthogdriver's Avatar
can you shift into 3rd/4th manually?
i think a tranny shop could pull codes for you that will give you a better idea what to look for.
i know some shops around me give free inspections..get one if you can. if its something you can do then you have yourself a shopping list for parts as well.
Old Oct 6, 2012 | 12:36 AM
I can't shift past 2nd, even manually. I'll check to see if anybody around does free estimates
Old Oct 6, 2012 | 10:16 PM
kabrynsdaddy's Avatar
kabrynsdaddy is on a distinguished road
You can take and pull the trans out buy the rebuild kit from like auto zone and take it to your local collage that has a autmotive tech class and they Will do it dirt cheap I went to Tennessee tech and they only charge people 5 didn't matter what we did to them if you need info on how to pull I can let you know also what trans fluid you running
uncle_egg820
Jul 8, 2012 01:33 PM
TDS-MN
Feb 7, 2011 09:05 PM
CincyFireman
Jan 27, 2011 03:48 PM
millerje78
Apr 28, 2007 11:22 PM
trueX
Aug 14, 2006 05:15 PM
