97 Automatic trans issue
Old Jan 24, 2016 | 03:00 PM
Red Sled's Avatar
Red Sled is on a distinguished road
Default 97 Automatic trans issue
97 Blazer with blown motor that still starts. 4x4 4 door. It has 3 button 4x4 switch. In 2 wheel drive no movement but if I switch to 4x4 it moves???? I have checked trans fluid and its fine. Anything else to look at????? 160K miles
Old Jan 24, 2016 | 03:05 PM
The only thing that could possibly cause this is a problem with the transfer case (broken rear output or transfer case in neutral instead of 2HI) or a problem in the rear differential.
Does the rear driveshaft move? If it does, I would open up the rear differential to see what's going on inside. If it doesn't, then the issue is inside the t-case.
comandoed
Dec 26, 2013 07:32 PM
bobf
Jul 21, 2012 01:03 PM
SA10A10
Jun 27, 2011 09:45 PM
cory.kiel
Jun 17, 2011 11:41 PM
pc_marshal
Aug 25, 2007 06:55 PM
