97 blazer tranny prob HELP
so yesterday i try and put blazer in reverse and i get nothing but revs up so i drive it around all and still never worked then i had a friend get under it and move linkage and it stated to work is that my problem or is it a bigger one
![](https://blazerforum.com/forum/images/kirsch/misc/progress.gif)
If you were able to move the shift linkage and get reverse, then I would say your issue is with an out of adjustment shift linkage.
You can adjust the shift cable.
CLICK HERE for a little pictorial of how to adjust the shift cable. The F-body has practically the same adjustment method.
LSpoweredStepside
09-30-2013 09:22 PM
