97 blazwer 4.3 engine miss wannafix it with dinomite soon please help
Old Oct 11, 2013 | 08:00 PM
  #31
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
OK. yes that is what I was wondering
Old Oct 11, 2013 | 08:54 PM
  #32
If the ground doesn't end up being the problem:
If you have the trailer tow option, there's already a 10 gauge battery feed wire back by the rear bumper. Connect it to a relay and use the grey wire to trigger the relay. Then run a wire to the fuel pump from the relay. Done that a couple of times myself In theory, all you need is 14 gauge wire for that distance and amperage. A little bit of overkill never hurt a thing when it comes to wiring.
Old Oct 11, 2013 | 09:03 PM
  #33
Cool thanks I will keep that in mind
Old Oct 13, 2013 | 07:11 PM
  #34
I didn't have a whole lot of time today I wanted to check the positive side voltage drop and I don't know if I didn't wrong but test lead from + to dvom then to back probe of the pump and my meter didn't change it went from 12.4v to 11.9 volts till the pump shut off. But when the pump was running I did hear a lot of fuel spray sloshing sound coming from the tank I'm gonna try the relay way o hooking it up but.was curious about the sound in the tank and why my meter didn't change to show voltage drop
Old Dec 31, 2013 | 05:26 PM
  #35
Well just an update I bought new injector pack from rock auto and installed it today runs great no check engine light. Holds fuel pressure 55psi after key is turned off
ussexplorer
Sep 27, 2013 03:38 PM
givemesnow
Aug 1, 2011 02:54 PM
jeffs91S10blazer
Oct 12, 2009 07:49 PM
Tony H
Dec 14, 2008 02:04 AM
kaercher4
21
Oct 13, 2007 05:42 PM
