'97 tranny issue
First... yes... I read the helpful "https://blazerforum.com/forum/tech-articles-diy-29/4l60e-information-common-problems-compilation-37689/" thread... so I am not a total moron... just a partial one.
Okay... so it could just be a blown fuse... somewhere... it seems. But let me preface my problem... so others can spot what was not clear to me... or noted in others thread.
It was driving great... good fluid level, nice and red, etc...
First I got the sudden ANTI-LOCK BRAKE sensor light on... then I lost the speedometer... then I started to get 'slippage like' high rpm revving.
Okay... so I then 'cure' this with manual shifting... I had 1-2-and 3 that was iffy.... but "D" was almost like N... and 'slippy'. So I stayed manually shifting from 2--->3.
When I returned today... I checked fluids again (fine)... and then added 1/2 pint of Seafoam TransTune.
NOW... it seems I have gotten the just learned of 'limp home mode'.
I seem to start in 2 only... and have 2 only... but R is great, N is N... and park works fine. (Anti lock brake light still on. And I have no speedometer needle movement, but tach is fine.) I'm staying in the 2500 rpm range... and then punching up to 4000 and then shifting to N when I need to coast farther and faster.
Okay... so anything stand out to anyone.
I custom build Scouts... so a TF 727 I could go over all day... but I am Chevy-stupid... so please bear with me.
Send answers and hate mail to me at: GotScout@gmail
Thanks, -Steve
Thanks, -Steve
Thanks for that... ironically... it is *now* running "perfect" again... (!!!).
This might have been a stuck valve that was cleared by the TransTune... (maybe).
But... I am wondering more about it all happening moments after the Anti Lock Light coming on. Is this typical?
I will have a code scan though... (to check solenoid warning statuses...) and do a fresh tranny drain and fill. It has been suggested to use ORIGINAL DEALER tranny fluid... as came from the factory. (real or hype?)
Thanks! -Steve
Thanks! -Steve
ski.dive
Feb 7, 2014 05:18 AM
wolv2401
Oct 30, 2007 04:25 PM
1st, 4l60e, blazer, common, compilation, high, information, problem, problems, rps, shifting, speedometer, tach, transmission
