98’ no 3rd or OD wants to but just revs
Old Mar 1, 2020 | 01:35 PM
Heatherh44's Avatar
Heatherh44 is on a distinguished road
Default 98’ no 3rd or OD wants to but just revs
Please help! I bought a 98 blazer the original owners said it just stopped going into 3rd gear. one day while she was stopped at a light took off no 3rd.... I found that when I got it home and was replacing the battery that the battery cable had corroded (was half gone) and ate threw a metal air tube coming from the exhaust. So I Replaced the battery cable, the battery, and the tube coming from the exhaust. i’m Wondering can the damage from the battery cable Grounding out and The giant hole it ate into the tube cause some kind of damage to the tranny? When I put it in drive it goes into 1st, 2nd fine but 3rd acts like it wants to go but it just kicks then just revs high... same when I do it manually 1-2 fine, 3rd just revs high. I’ve checked the fluid it’s fine, and the fuses they are all good. ???? Any help would be appreciated
Old Mar 1, 2020 | 01:50 PM
Sound like a bad 3/4 clutch pack. A replacement or rebuild will likely be in order.
Old Mar 2, 2020 | 06:25 AM
Transman304's Avatar
Welcome to the forum. As christine_208 posted is most likely the issue you are having. One of the most common issues experienced with this transmission model. The battery cable is not likely the cause of what you described. Unfortunately this kind of repair would require transmission overhaul or replacement. Good luck.
Brad
Old Mar 2, 2020 | 10:22 AM
Brad
And if you have to have the transmission removed, have the rear main seal for the crank checked. This is not often a problem but while the transmission is out would be the best time to have it looked at.
Old Mar 4, 2020 | 05:00 AM
93S10TahoeLT's Avatar
Or the engine out..
Cessnaflyer
Dec 25, 2011 10:50 AM
mikejsansone
May 1, 2011 12:01 AM
jtorg2008
Jan 12, 2011 02:10 PM
87ChevyBlazer
May 13, 2010 05:51 AM
leeclark
Apr 12, 2009 04:33 PM
